Old 12-Aug-2011, 11:02 PM   #6
John Candle
Tv Antennas and Reception
The only VHF low band digital station is K02KN 02 and it is a low power Repeater station of PBS. K07CG 07 VHF high band , is a low power Repeater station of NBC and are located to the north east in the opposite direction of the other stations to the west and south west. . A all channel Directional antenna is the Winegard HD7082P , however the HD7082P antenna will need to be on a rotor to aim the antenna at other Tv stations , and this does not work well with more then one Tv. . A antenna that you can try. That will receive Tv transmissions of many different directions is a Winegard MS2000 , when installing the MS2000 it will likley need to be turned to find the best position for reception in different directions and then tighten up the clamps. . Here are places to buy Tv antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
