Old 12-Aug-2011, 9:03 PM   #4
Dave Loudin
You're very close to your local transmitters, so a modest antenna, like the RCA ANT-751, will be just fine. If you want to chase the Buffalo stations, you will need a much larger UHF antenna, like the Antennas Direct DB-8, Winegard HD8800, or Antennacraft U8000, that can be aimed right at them. Run separate feeds from the antennas to an A/B switch at the TV.
