Old 11-Aug-2011, 3:48 PM   #4
oakknoll
Can you describe your antenna system?
Antenna make & model
Mounting location & height AGL
Aimed in what direction
Accessories such as amplifiers, splitters, switches, etc.
Coax type & length
Number of sets connected
Thanks
Thanks GUM,
Antenna is an RCA ANT1500 Multidirectional
approx 20ft from ground level
current positioning is perpeindicular to signal tower
runs through Tivo box (one) no splitter involved
coax, was existing, unknown of type run is maybe 35 ft.
single TV
note: a test of positioning the antenna at 10ft off ground using 6ft coax shows the signal to remain the same. All Stations excepting KLSR are good.
oakknoll is offline   Reply With Quote
