Tv Antennas and Reception
Some cheap coax , the center conductor with the foam surrounding the center conductor is so loose in the the rest of the jacket of the coax that the center conductor slides in side of the outer jacket and the center conductor does not make contact with what the coax is connected to. Just because something has to be good , does not mean that it is. . If any thing can go wrong - It Will. . If the coax is tagged as to where it goes , it does not mean the tag is correct , the tag could say . liv room but really go to m bed room - master bed room. If any thing can go wrong - It Will. Cut coax , nails , screws in coax , coax that is installed and goes no where. Coax that is not connected behind wall plates. Just because it is supposed to be Ok does not mean that it is!! If any thing can go wrong - It Will !!
