Old 31-Mar-2010, 2:04 PM   #3
Dave Loudin
With an antenna height of 20 feet and a 2-edge propagation path, you are indeed facing either an attic or roof installation. There's also a PBS and a low-power station on UHF in the same direction. If you're interested only in KMVT, then a Winegard YA-1713 or an AntennaCraft Y10-7-13 would suffice. Angling for the UHFs in addition would require getting an AntennaCraft HBU-33 or Winegard 7696P instead. You might need a pre-amp to compensate for losses in the coax cable from antenna to TV that would cause drop-outs, but you could try without one first.
