Old 5-Aug-2011, 3:45 PM   #5
John Candle
Tv Antennas and Reception
To see if signal strengths increase to more usable strength. Like KEYT ABC from the Very Low -15.8 NM (dB) to a stronger signal of , say , - 5.0 NM (dB) or better yet , + 5.0 NM (dB) . Make two more radar plots at , 60 feet and 100 feet. Also you can go to the , >>Start MAPS<< part of tvfool and move the pointer around and change the height of the receive location to improve the reception. . Tv antennas receive the best when Nothing is blocking reception. The more the signal is blocked by , mountains , hills , buildings , trees , and etc. . the less will be received.
