Old 5-Aug-2011, 6:33 AM   #10
Thus, the overall observation is that the C5's gain is about 6 to 7 dB below the Y10-7-13's, and if we accept that the Y10-7-13's gain is close to the published 10 dB, that would imply the CM4228HD's Hi-VHF gain is about 3 to 4 dB across the Hi-VHF Band.
The published specs for the HD7694P indicate 9.6 dB of gain and 38° 1/2 power beam-width @ CH-9. If an HD769X series antenna will fit in the space available, it's clearly a superior one-antenna solution compared to a lone UHF panel antenna.
Now, if KCPQ is not received well through the side, a Channel Master CM0538 Join-Tenna and the previously mentioned Antennacraft Y-5713 could provide KCPQ-Fox, if it is desired.
