I suggest the Antennacraft U8000 8 bay panel antenna with a Winegard HDP269 preamp aimed at about 210 degree magnetic compass. This antenna I have recommended to others because it receives well in 2 directions , front and back. Do the coax wiring in a way that uses the least amount splitters , Every time a split takes place the signal is reduced. The worst to do with splitters is have a run of coax and then a splitter and from that splitter an other run of coax and then a splitter and from that splitter an other run of coax and then a splitter , there won't be any signal at the end. The best to do is have one splitter and run a coax out to each Tv.
