An RCA ANT-751 or the HD1080 would be appropriate in your situation. Both can easily wall mount if desired. In either case, the aim is broad but Channel 10 arriving from the side may give you some trouble. I would try one antenna to begin with... if you find it necessary, there are a few ways to add a second antenna, lest's cross that bridge if you find the need.
