The next way to do it is a HD7694P aimed at 140 degree magnetic compass and a Channel Master CM 4221HD aimed at 251 degree magnetic compass. Two separate coax will go from each antenna to the area of the Tv where a remote control A/B antenna switch such as , AB27RS or radio shack 15-1969 will be located to switch from one antenna to the other antenna.
