Old 1-Aug-2011, 4:55 AM   #11
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You'll find that the Winegard antennas usually have a bit better UHF reception than the comparable AntennaCraft antennas. If your primary concern is the DC stations, that won't matter much, but if you are going to try for the Baltimore stations, then I would suggest going a bit larger and getting the Winegard HD-7697P. If your antenna rotator motor is still functional, buying the CM9537 is probably not a bad idea, but will be of limited usefulness in getting the DC and Baltimore stations. You have no VHF low-band channels (real RF channels 2-6) of any significance in your area, so the suggestion of using a Winegard HD-7082P is probably not of much use to you.
