Tv Antennas and Reception
Quote , WNVT-DT 30 is very strong and should be received through the back side of the antenna. End Quote. The signal is very strong and reception should take place with out having to rotate the antenna to the direction of the Tv station WNVT-DT 30. . . Now you say you are considering a HD7697P and not the HD7694P antenna.
