Tv Antennas and Reception
I recommend a Winegard HD7694P antenna and a Winegard HDP269 preamp aimed at 57 degree magnetic compass. I do not recommend a rotor. Do not use the amplifier that you say is built in to the old rotor. I recommend replacing all the coax cable with new RG-6. I recommend replacing all coax couplers and splitters that are outside. WNVT-DT 30 is very strong and should be received through the back side of the antenna.
