Old 31-Jul-2011, 2:43 PM   #4
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You will be able to see all the DC stations as well as most of the Baltimore stations if you invest in the right antenna system. If the Baltimore stations are NOT important to you, consider installing a Winegard HD-7694P mounted on your roof along with new RG-6u coax cable and a high-input preamp like a Winegard HDP-269. Aim the antenna at roughly 55 degrees by your compass, you you may want to re-purpose your old rotator to turn the antenna. If Baltimore is of interest to you, use a bigger antenna like a Winegard HD-7697P instead of the HD-7694P. He Baltimore stations lie in almost exactly the same plane as the DC stations do, and should come in without rotating the antenna if you choose to look for them. Good Luck!
