Tv Antennas and Reception
Replace the outside coax cable with all new RG-6 coax. If a coax grounding block is connected , replace it also , if there are splitters outside replace them. You need to get the signal to the Tv , not be stopped by bad hard ware , bad connections , bad coax. Using amplifiers to Ram the signal through , bad hardware , bad connections , bad coax , is not the correct way to do it.
