Old 28-Jul-2011, 2:20 PM   #10
Originally Posted by drick View Post
Any recommendations on an antenna? How do I go about connecting the antenna together?
Any UHF only antenna is fine for 4.1. You can combine the antenna with a Jointenna for channel 25 if you can find one or Tinlee will custom build one. The cheapest option is an A/B switch.
An alternative is PBS from WBRA on channel 3. You can combine a low band VHF antenna (Y5-2-6) using a cheap HLSJ combiner. But a low band antenna will be large, and your signal strengths mean an outdoor install.
