Old 28-Jul-2011, 8:58 AM   #10
John Candle
Tv Antennas and Reception
The answer is NO. Omnidirectional directional antennas indoors do not work well , the reason is all the signal reflections (multipath) indoors , and having a omnidirectional amplified indoor antenna amplifies the signal reflections and makes the reception even worse. If you will like to try a standard indoor type antenna then try one of these , http://forum.tvfool.com/showthread.php?t=233 . These standard rods and loop type indoor antennas have been around for a very long time , the reason is they work , and the fancy wiz bang antennas fail. For your location extend the rods out length ways on a north south line. And adj. the rods to a low V shape. The antenna will receive better close to window that is in the direction of the transmitters.
