I recommend use a Channel Master CM3418 eight way distribution amp. Put 75 ohm terminators on any unused outputs of the distribution amp. I Strongly Suggest move the antenna to the outside for much improved reception , above the roof , up at the top. Also as a experiment , I suggest order a Winegard MS 1000 omnidirectional antenna and mount it above the roof in place of the CS2. Please note that omnidirectional antennas are not 100 % omnidirectional , might need to turn the antenna to find the spot that receives the most Tv stations in every direction.
