Old 26-Jul-2011, 6:09 PM   #1
drick
Clearstream 2 Pre-Amp or Distribution Amp?
All, enjoy the forum and thanks in advance for the help. I have installed a Clearstream 2 antenna in my attic and want to get some advice regarding the use of a pre-amp or a distribution amplifier. I would like to send the signal to 5 TVs. Here is my report along with other specifics:
http://www.tvfool.com/?option=com_wr...03f3eda18892a3
  • Antenna mounted in attic and approximately 25 feet high
  • Cable runs from antenna and then downstairs with no splitters approximately 30 to 40 feet of cable
  • I have the cable hooked up to a 4-way distribution amp that I picked up at Home Depot for $15
  • 4-way Distribution amp feeds 5 TVs from that point; 3 outputs to 3 TVs (approximately 30 feet cable each) and one output feeds 2 TVs with one splitter (another 30 feet of cable)
The 2 newer TVs with digital tuners have great reception and the signals in my area are really strong. However, I have 2 primary issues:
  • The PBS station (4.1) does not come in as strong as I would like on any of the TVs
  • The other 3 TVs are older and I've only tried the convertor box on one. That one TV has a VERY hard time keeping the PBS station AND does not pull in near the number of channels as the newer TVs (20 stations vs. 35)
With this set-up from above, do I need to be using a pre-amp or is the distribution amplifier the way to go? Or, do I need both?? Is the distribution amp that I have (which again, was only $15) inadequate? What heading should I have my antenna pointed towards??
Any and all advice, input or suggestions would be greatly appreciated. I've tweaked and tweaked and my wife is running out of patience!
Thanks.
drick is offline   Reply With Quote
