Old 26-Jul-2011, 2:44 AM   #9
wpbacon
At most, three tv's and an HTPC with 4 tuners (a dual and 2 single)will be connected.
The installed coax is no longer connected together. I just moved into the house and the former occupants "cut" out the distributor/amplifier instead of unscrewing the lines. They're just hanging down in the basement. However, it is a structured wiring setup.
I didn't know about grounding the installed coax, I'll get that done and let you know if it changes anything.
I'd really like to get KLKN-DT (Digital) Channel: 8 (8.1) Network: ABC, it's about 60 miles away. Might it be better to use the DB8 for the close Omaha channels and add a directional second antenna to try for this station?
wpbacon is offline   Reply With Quote
