Old 24-Nov-2014, 7:36 PM   #1
b2471041
Help with antenna selection, report included.
Here's my report.
http://www.tvfool.com/?option=com_wr...d243c252cc42fa
I'd like to get KCBS, KNBC, KTLA, KABC, and KTTV. On the plus side it looks like they are all from the same location so one antenna should work. I'd like to mount it in the attic because of high wind conditions that can exceed 60mph gusts. But I can also mount in on the roof which will give me the 25ft height.
I currently have an old antenna from the 80s and it barely pulls in any channels. Pretty much just KTTV and KCOP which makes sense given the chart. Can it still be used or the parts used to build a new antenna one?
Only need to supply signal to one tv that would require a 40ft coax cable run if that matters.
Thanks for any suggestions.
b2471041 is offline   Reply With Quote
Old 24-Nov-2014, 8:53 PM   #2
timgr
Originally Posted by b2471041 View Post
Here's my report.
I think you'd be shooting yourself in the foot by putting it in the attic. Even the most favorable attic roof is still a big handicap. And you don't have any signal to waste.
KCBS is difficult to impossible with that chart. -7.5 NM is way down. You might do better if you go higher.
How much do you want to spend?
Old 25-Nov-2014, 12:34 AM   #3
b2471041
Budget of $100 or thereabouts would be nice. I don't mind mounting it to the roof as there's an existing pole but it just needs to be sturdy enough to survive some occasional high winds.
So I saw some DIY antennas and decide to build a Single Bay Gray-Hoverman Antenna. I'm actually able to pick up a lot of channels including CBS. But KABC and KCAL have poor signals reception of 30 or less whereas the other channels are at 50-60.
