Old 28-Nov-2013, 1:11 AM   #1
dexxa
Trying to get WTOL in Toldedo From Warren,MI
I'm trying to get WTOL from Warren, Mi it looks like its only 57miles south of me? i have a 7inch portable tv i took out in an open field and tried it with a vhf antenna small one but still didn't receive it? Any Idea?
http://www.tvfool.com/?option=com_wr...&q=call%3dwtol
dexxa is offline   Reply With Quote
Old 28-Nov-2013, 1:22 AM   #2
StephanieS
Hi Dexxa,
We'll be happy to check it out for you and give a thought or two as to what your options are.
First though, could you run your radar plot at:
Then post your results for us to see. The more details and information we have about your location and how you wish to set things up, the more help and advice we can give.
SS
Old 28-Nov-2013, 1:40 AM   #3
dexxa
Here is the radar plot
http://www.tvfool.com/?option=com_wr...46ae1cb4b46e9d
Old 28-Nov-2013, 2:53 AM   #4
StephanieS
Dexxa,
Thanks. That is more helpful. You might want to run it with your specific address so the detail is a little stronger. Currently, your radar plot only provides for reception at your block level. However, it does give me baseline to work with.
First comment, lovely tvfool report. You ought to have many reliable signals.
As to WTOL CBS on RF 11, a small VHF antenna isn't going to be the correct application. WTOL is in the weak category and requires a larger, high gain VHF antenna to be received.
I would be inclined to suggest a Antennacraft Y5-7-13 dedicated H-VHF beam mounted on your roof pointed at magnetic 203 for reception of WTOL.
Thus this would be a two antenna set up complimented by an RCA ANT751 for local signals pointed at about magnetic 200. I wouldn't try to do a one all antenna solution here because of the diversity of signal strengths. When we try for weaker signals, many of us use specific antennas for them. If signals are strong, we let one antenna handle most of those if we can.
Your trick pointing the Y5-7-13 is that you have strong signals off to each side. That said, via the Y5-7-13, you may also see ABC WTVG as well. Due to those mentiond strong signals, you may not be able to run a preamp.
Do you have a set up currently or are you building from scratch?
Old 28-Nov-2013, 3:15 AM   #5
dexxa
I did put in my address but this is what i got back "WARNING: Address was only resolved to block level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates."
Old 28-Nov-2013, 4:55 AM   #6
When generating a TV Fool report, my preferred method is to open the Interactive TV Maps tool. Leave the 'input method' set to the default, 'address'. Then, enter only the Postal Code, and then click the 'Map This' button.
At this point you should have a map displayed, with a movable cursor located at the center of the Postal Code that was entered. Use your mouse to drag the cursor to the exact location you're interested in. In the upper right corner of the map you can select fview types, I find it helpful to use both.
At the bottom of the map, enter the antenna height. Please use the highest value that you can safely consider installing. If you aren't sure, then use 25'. FWIW, You can also find the LAT/LON coordinates of the cursor (in decimal form, not deg/min/sec).
Once the cursor location and the antenna height are set correctly, click on the 'Make Radar Plot' button located at the upper right corner of the map. The TV Fool report opens in a new tab or window. You can then copy the URL from the address bar of your browser, for posting to a thread.
I hope this helps, I just want to be sure we give you advise based on the actual conditions at your location.
Old 28-Nov-2013, 5:11 AM   #7
dexxa
Ok, I did the radar plot
http://www.tvfool.com/?option=com_wr...46ae63af34aa71
Old 28-Nov-2013, 5:23 AM   #8
I would be inclined to use an ANT-751 pointed toward the west... For reception of most of the available signals.
To get WTOL reliably, I'd go to the Antennacraft Y10713 and then use this technique: http://forum.tvfool.com/showthread.php?t=2882
If you locate a preamp (such as the RCA TVPRAMP1R) at the antenna, you may find the UHF capability of the Y10713 is fair or even good. A preamp will isolate the antenna from the coax run, thus reducing some of the negative effects of poor SWR in the UHF band. Regardless of whether you receive UHF 40 or 47 with this technique, I think you'll benefit from the preamp when tuned to WTOL.
Old 30-Nov-2013, 8:34 PM   #9
dexxa
I picked up the Antennacraft Y5-7-13 dedicated H-VHF beam antenna still with no luck i pointed it at 203 degrees Also scanned for digital channels and also hit 11.0 for WTOL and just fuzzy... Also turned the antenna by hand to see if i could get it.. NO LUCK!
Old 30-Nov-2013, 8:52 PM   #10
Few tuners provide for direct entry of a channel. Unless your TV instruction manual indicates otherwise, you can assume that you must scan to add a channel.
Consider doing a double scan: http://www.sbgi.net/template/shared_...can_Notice.pdf
I would have chosen the Y10713... Experiment with alternate mounting locations and heights.
Old 30-Nov-2013, 10:24 PM   #11
StephanieS
What is your set up? Do you have a preamp on the mast? Are you splitting your coax to multiple TVs? What is the length of coax run? Does your TV have a menu that you can manually enter the channel then choose "signal strength" to see at what level RF 11 is being received?
Did you attempt this from your roof? Is the antenna free and clear of obstructions at magnetic 203?
If your TV has a menu feature that you can "see" signal strength, that'd be helpful.
You may need to test a couple alternate locations. "Dead spots" aren't uncommon and moving antenna locations in some cases a few inches to a few feet can yield great improvements in reliability.
The more info we have, the more we can figure it out. First step is if there is a signal on RF 11 with the Y5-7-13 and at what level.
Edit: A further idea, with the Y5-7-13 pointed at magnetic 203, test reception at night. Often during daylight hours due to atmospheric conditions weaker signals can fall below reception threshold.
Old 1-Dec-2013, 3:47 AM   #12
dexxa
No preamp installed pointed the antenna at 203 magnetic and NO mutiple tv setup yet. just pointing at WTOL location my rca 7inch tv has signal meter and i am able to tune to channel 11 but snowy so i turned the antenna little back and forth to see if i was able to get it..but nothing... Also antenna is on top of roof about 20ft high Also tested it at night to see NOTHING! I am running cable 50ft and also went over to a field near me open space nothing around and still not a damn thing spent all day on this project.
Old 1-Dec-2013, 5:10 AM   #13
Fuzzy and snowy are words that describe Analog Tv reception.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
Digital Broadcast Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Last edited by teleview; 1-Dec-2013 at 6:24 AM. Reason: Clarify information and typos.
Old 1-Dec-2013, 5:20 AM   #14
Presuming the 7" RCA TV is equipped with a digital tuner, I have to presume you will need to perform a channel scan each time you reposition the antenna. However, it's best that you check the manual for that TV...
Most TVs with ATSC tuners will not accept direct manual tuning, or simply sweeping the horizon with the antenna... Some will accept direct entry but only through the menu (manual add mode). Again, what does the manual say?
Old 1-Dec-2013, 5:56 AM   #15
StephanieS
Yes, did you do a tuner rescan?
I hear the frustration in your voice. Remember, TV antenna installs are sort of a black art. There are many variables at play, sometimes you have to work through them to find the solution you want.
An idea is that I might try another receiver other than the RCA 7". If your indoor TV is your final destination, I would conduct my testing on that TV as it's tuner is the one that will be used daily.
I am leery or recommending a preamp to you. The RCA TVPRAMP1R serves me well and has a good tolerance for strong signals. In my situation, I have 65 db signals off to my side, while you have 71 db. You are also much closer than I am to your strong signals transmitters.
I would:
A. Test on indoor TV, doing a complete digital channel rescan with only the Y5-7-13 patchd into the TV.
Do this rescan each time you fiddle with it.
B. If A unsuccessful, order and test RCA TVPRAMP1R on Y5-7-13
C. If A and B unsuccessful order Y10-7-13. Test Y10-7-13 with and without preamp to determine best reception situation.
You are seeing other signals on the Y5-7-13 yes?
Old 1-Dec-2013, 6:51 AM   #16
I suggest going by Radio Shack & purchasing an FM trap as the next step. You have an EXTREME amount of FM energy at your location. It is likely overwhelming the tuner & preventing it from seeing the weak channel 11 signal.
The Y5-7-13 antenna may not be enough antenna either, but I would see what happens after trying the FM trap between the antenna & TV.
Old 2-Dec-2013, 11:10 PM   #17
dexxa
Good News!! picking up wtvg in toledo but no WTOL keep scanning to pick it up!
Old 2-Dec-2013, 11:54 PM   #18
StephanieS
This is a good sign as WTVG is 2.6 db 7 db weaker than WTOL.
Was this with the FM trap as No Static At All suggested?
Old 3-Dec-2013, 12:18 AM   #19
dexxa
Just cam seem to get WTOL In my crossahirs.
Old 3-Dec-2013, 12:19 AM   #20
dexxa
Yes I do have the radio shack FM trap on the antenna
