Old 3-Mar-2020, 10:30 PM   #21
Tim
Originally Posted by mikmaze View Post
my setup currently has the antenna on a simple pipe, not guy wired. Does it look like it would be worth going up another 10 or 15 feet and guy wiring for a clearer shot at cleaner signal? I have messed with the settings on the height field in rabbit and see improvement, just not sure how much it would help.
My "guess" is no, but the only way you'll ever know is to try it and see.
Old 26-Mar-2020, 4:01 PM   #22
mikmaze
o joy, more money to spend... https://www.techhive.com/article/351...v-upgrade.html
mikmaze is offline   Reply With Quote
Old 5-Apr-2020, 2:53 PM   #23
mikmaze
I see atsc 3 will allow for companies to bundle up channels and charge for reception.........
Old 5-Apr-2020, 9:22 PM   #24
OTAFAN
This might clarify a bit.....
Old 7-Apr-2020, 12:03 PM   #25
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Hi Mikmaze,
I'm not much of a tech guy, I'm usually the one asking the questions but I have gained some experience over the years. In your case I would definitely try to go higher. I have several ideas on masts and Guy wires. I will call mine a poor man's Tower, if you're interested, I can get you some ideas on that.
At any rate these guys on TVFool are the best in the business. Your conversation has attracted some good Minds here. I like the suggestion of the DB4e for the wider reception area. From what I understand four bays are very good when your transmitters are separated.
If you're willing to go up higher with your Mast maybe you could consider ganging/stacking two antennas.
Maybe stacking 2DB4e's ? I'll keep an eye on this thread.
http://forum.tvfool.com/showthread.php?t=1024
Old 7-Apr-2020, 10:41 PM   #26
mikmaze
oops, posted this kind of again as my post seemed lost for a day or so...........
sure, we cut the cord and they figure out another way to charge us............
https://www.techhive.com/article/353...d-cutters.html
Old 9-Apr-2020, 12:08 AM   #27
mikmaze
doesn't seem too long that we just may need a new tuner box to take in the atsc 3 signal and view it.
Old 9-Apr-2020, 11:48 AM   #28
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
So, let's get back to the subject. What have you done to improve your reception? We all want to help you but we want to see some progress!
Old 9-Apr-2020, 1:33 PM   #29
mikmaze
sorry, have not made it back up tot he cabin yet, 200 miles from home, not a quick trip to see or try anything. Thinking of going with the db8e, possibly combine signal with existing unit, it has to add something o the signal. with the whole virus panic that is around might take a bit to get up there. the db8e to me, looks like a pair of db4es combined.
