Old 25-Apr-2019, 6:58 AM   #121
blackstone
Here's an update.
Installed the PA 18 preamp on the Channel Master. Already had one on the DB8E.
Used the combiner that I had on hand from Antennas Direct.
Connected to the CM distribution amp and got stations without the interference.
Tried without the distribution amp and lost many stations.
Re-connected the distribution amp.
I get every station available except WPGH 53.
Had a couple rainy days and that affected my reception.
Since I have now received my UVSJs, would there be any value in trying one of them in place of the Antenna Direct combiner?
I think I'm about as optimized as I can for my location unless there are other suggestions.
Thanks to everyone for all the generous, patient help.
TV Fool is a fantastic resource and this forum, with all the great people, is a true asset for techno-dunces like me.
If there is some way I can support this or contribute a little something to the ongoing upkeep, please let me know.
I still have some spare UVSJs if anyone needs some
blackstone is offline   Reply With Quote
Old 25-Apr-2019, 2:44 PM   #122
Tim
It is so easy to change out that you could certainly try it. Most likely it will make no difference, but if it were me (being the curious type) I would certainly give it a try just to see what happens.
Old 25-Apr-2019, 3:11 PM   #123
Here's an update.
Thank you for the update with your report of improved reception.
Your current TVFool report doesn't list WPGH because of database errors used to generate the report.
However, a report from rabbitears.info does list WPGH, and its list of channels should be more accurate. WPGH is listed as much weaker than your other channels.
It should work about the same as the Antennas Direct UVSJ. If you are curious, maybe you should make a temporary test.
Yes, I agree.
WPGH is moving to channel 20 during Repack Phase 4, 6/22/2019 to 8/2/2019
https://www.rabbitears.info/market.p...&callsign=WPGH
They might be running at reduced power because of antenna work.
The fact that you thanked us and gave a report of improved reception by following our advice is sufficient; it's what keeps us going.
Enjoy your new setup.
Best regards,
rabbit
Old 25-Apr-2019, 3:47 PM   #124
blackstone
Or I could continue to ask dumb questions for others that are too embarrassed.
There are times that WPGH comes in, usually poorly.
Will the repack improve or diminish my chances at receiving WPGH?
Old 25-Apr-2019, 6:57 PM   #125
If it is running at reduced power now to work on the new channel 20 antenna, you should see some improvement. If it is not running at reduced power now, your reception will be about the same.
The channel 20 transmitter will be running at a little less horizontal power because it is on a lower channel which requires less power for the same coverage area. Coverage area is important to the companies that are paying for the ads.
click on Technical Data
channel 43
1000 kW ERP horizontal polarization
55.6 mile contour / 9726 sq. mi. area / Est. Pop. 2,976,383
channel 20
800 kW ERP horizontal polarization + 343.2 kW ERP vertical polarization
57.2 mile contour / 10284.5 sq. mi. area / Est. Pop. 3,128,179
Old 25-Apr-2019, 8:36 PM   #126
blackstone
Thanks, rabbit 73.
I don't understand the numbers you posted other than KW.
Just have to wait and see
Old 25-Apr-2019, 10:07 PM   #127
Thanks, rabbit 73.
Effective radiated power (ERP), synonymous with equivalent radiated power, is an IEEE standardized definition of directional radio frequency (RF) power, such as that emitted by a radio transmitter.
WPGH has a transmitter with an output of 45.6 kW
It also has an antenna with a gain of 13.41 dB that makes the output of the transmitter stronger
45.6 kW + 13.41 dB gain = 1000 kW ERP
and this is the WPGH coverage map for 55.6 mile contour / 9726 sq. mi. area / Est. Pop. 2,976,383
Old 25-Apr-2019, 10:37 PM   #128
blackstone
Thanks for the explanation.
What does vertical polarization do?
Old 25-Apr-2019, 10:48 PM   #129
The horizontal polarization of the transmitting antenna matches the horizontal polarization of your receiving antenna for the most effective reception.
Some vertical polarization has been added to the horizontal polarization of the newer antennas with the hope that it will make the reception of the new ATSC 3.0 signals more effective for mobile devices.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
