Old 30-Aug-2018, 12:38 AM   #1
realjet
Help with antenna selection
I posted a thread in Dec 2017. This is an update to that. I have a different lot which is close to the other one but this one is actually higher up. I moved my camper there a few months ago. It has a built in "wingbat" antenna on the roof. There is a built in pre amp in the camper. I am able to get some local stations like ion, pbs, and a few others. I am able to pull in cbs from atlanta but not all the time. Any new recommendations for an antenna?
Here's my new report: http://www.tvfool.com/?option=com_wr...903838762dbc22
Here's my old thread: http://forum.tvfool.com/showthread.php?t=16405
I also have a channel master preamp here at my house that I could use. https://www.channelmaster.com/Amplif.../cm-7777hd.htm
realjet is offline   Reply With Quote
Old 30-Aug-2018, 2:08 PM   #2
Nascarken
Banned
It has to be up higher but the roof mount of the antenna will not let you do so
So get the camper it self up in a higher eluvashion should work well !!!
Old 30-Aug-2018, 4:40 PM   #3
realjet
I should have said that this is a permanent location now for the camper.
I noticed that the stations that I want from Atlanta are all UHF and in basically the same location. Would a good UHF only antenna work?
Old 30-Aug-2018, 6:21 PM   #4
Nascarken
Banned
Yes go with the solid signal HDB,91 the antenna is on sale with free shipping
And I suggest the channel master 7777-AMP!! And use Rg6, 18 gage solid copper!!!
And use a 3ft tripod on a 10Ft pole? So do a tv Fool report with the Hdb,91,and
The 7777,channel master amp the higth of the camper+the 10ft pole.
Let me know what the tv Fool report is with the ANTENNA set-up?
Old 30-Aug-2018, 6:55 PM   #5
jrgagne99
Your TV fool report was only resolved to block level, and so it is likely not accurate. Use the instructions in the sticky thread "A reliable method for generating a TV Fool Reception Report" to get a more precise report. Make sure to zoom all the way in and put the push-pin right on the RV site as seen in the satellite imagery. Enter the expected height of the antenna Above Ground Level- AGL (not the antenna type and pre-amp as prior post suggests). Also, please list the stations you wish to receive (by their call letters) so we can make a proper system recommendation.
Old 31-Aug-2018, 12:05 AM   #6
If you look closely at his TVFool report, you will see his exact address, which is consistent with the fact that he gave the coordinates for his former location in his previous thread.
Old 31-Aug-2018, 12:43 AM   #7
Welcome back, realjet
Your new location has higher elevation, which should help, but it isn't the highest in your area.
Old 31-Aug-2018, 1:04 AM   #8
realjet
This is correct. Please forgive me but I'm not that tech savie.
Old 31-Aug-2018, 1:15 AM   #9
realjet
Will this work? I already have the cable and a mast to put it on.
Old 31-Aug-2018, 2:11 AM   #10
That is a good UHF antenna that will work for ION or PBS if you aim it at them, but not for your VHF-High channels from Chattanooga, real channels 13, 9, and 12.
It is the real channel number (also called physical channel or RF channel) that determines what antenna is needed.
VHF-Low, real channels 2-6
VHF-High, real channels 7-13
UHF, real channels 14-51
The virtual channel number (like 5.1 or 5-1) is a holdover from the analog TV days to maintain the identity of the station, and is what the TV displays. By convention, the virtual channel number is given in the decimal form to keep it from being confused with the real channel number.
I suggest a Stellar Labs 30-2476 VHF antenna aimed at Chattanooga and your CM7777HD preamp. It might help to tilt the front end of the antenna up a little to catch the signals coming down from the mountain peak. You can mount the preamp a little lower to reach it more easily and play with the high/low gain button.
https://www.newark.com/stellar-labs/...vhf/dp/71Y5462
If you want ION or PBS, try an Antennas Direct DB4E, combined with your 30-2476 using a UVSJ UHF/VHF combiner between the antennas and the preamp.
https://www.amazon.com/Antennas-Dire.../dp/B008PBTPN4
I can't guarantee that this will work, but it is your best chance.
Old 31-Aug-2018, 3:15 AM   #11
This is the problem with the signals from Chattanooga; there is a mountain in the signal path:
Old 31-Aug-2018, 4:17 PM   #12
I agree that the Stellar Labs VHF antenna is a good choice.
This is one of those situations where you can take advantage of ground gain to tilt the signal up instead of tilting the antenna. If you can figure out the optimum height, the ground gain can be as high as 6 db. For this to work, the slope of the land in front of your antenna must also be considered. The angle from your location to the mountain that will reflect the signals from WTVC is about 2 degrees uptilt.
http://www.qsl.net/oz1rh/gndgain/gnd_gain_eme_2002.htm
Old 31-Aug-2018, 9:02 PM   #13
Nascarken
Banned
Well I have suggest the HDB,91 which is a uhf only antenna but if you're looking to get
Hi and low band vhf,and looking for the uhf,also go with the Winegrud 8200U ?
With the channel master 7777AMP you will be happy with it lol put this in your tv Fool report and see what you THINK before you buy the antennas that we all have suggest to you!!good luck.
Old 1-Sep-2018, 1:05 PM   #14
realjet
How do I put this in my tv fool report?
Old 1-Sep-2018, 4:17 PM   #15
Nascarken
Banned
Just like the antenna you put in
The first time but put in hdb.91
Or 8200u with a channel master
7777AMP!!??
Old 1-Sep-2018, 6:58 PM   #16
I don’t see the possibility of picking up any low land stations(channels 2-6). Therefore the huge 8200U is much too big and too expensive. I’d use the Stellar Labs antenna aimed at Chattanooga, and then add a UHF antenna aimed whereever you desire to receive a UHF station.
Old 1-Sep-2018, 8:28 PM   #17
realjet
7777AMP!!??
I'm sorry but I never put a antenna in. I don't see where to.
Old 2-Sep-2018, 4:03 AM   #18
The reason you don't see where to put your antenna in your report is because there is no place to put it in. You can put your antenna height above ground, but not your actual antenna.
The report assumes that a simple dipole antenna is being used, and gives Noise Margin and signal power based on that. You can add your actual antenna gain to those numbers after you receive your report to see how much it will help.
Old 2-Sep-2018, 11:33 AM   #19
Nascarken
Banned
Ha tower Guy!!but soon low vhf will TACK off !!!
And maybe he should probably tack a look at the king Jack design for
The camper with it's new single finder and IT'S RECEIVE of,70 miles.
It's just a lot better than the batwing,ANTENNA lol!!!!
Old 2-Sep-2018, 1:37 PM   #20
What does TACK off mean?
