Go Back   TV Fool > Special Forums > General Site Feedback / Discussion
Old 8-Apr-2012, 8:02 PM   #1
frank55
frank55's Avatar
Antenna web?????
Hi guys,donīt know if you noticed that when you go to antenna web for pointing antenna and available channels in you area , they only give you few Chan nothing like here at fools that give you all available Chan,my question! are they misleading you cause they only want you to watch locals at your area? and donīt want you to get Chan farther away?or want you to join the TV providers?
frank55 is offline   Reply With Quote
Old 8-Apr-2012, 10:02 PM   #2
Electron
Tv antennas and Tv reception
We are all aware of what is happening with antennaweb and more a lot more. There is No conspiracy with antennaweb. When tvfool is typed into the google search box , tvfool web site and other web sites pop up that deal with what you are saying. Whipping up a lather will not work here at tvfool.
Old 8-Apr-2012, 10:29 PM   #3
If you are pointing out the superiority of TV Fool's service, I agree.
On the days that I'm somewhat rational, I don't see many conspiracy theories lurking in the bushes.
Old 8-Apr-2012, 10:58 PM   #4
frank55
frank55's Avatar
for me is conspiracy cause i get about 34 Chan with my set up that's what TV fool gets me more or less, when i type same info same antenna i get 8 Chan or so,
check this out
http://www.antennaweb.org/Stations.a...Lon=-71.142593
Old 9-Apr-2012, 2:39 PM   #5
Dave Loudin
Antenna Web is keyed to market DMAs, and will only show stations in your DMA that have a service contour that touches your county. It's just a different, simpler method to figure out what's available.
The FCC has a prediction tool that works like TVFool, but presents the results in a simpler way.
Old 10-Apr-2012, 3:35 PM   #6
Antennaweb's prediction tool is:
1) Extremely conservative in the signal forecast levels.
2) Of much coarser resolution than the algorithm that TVFool uses.
3) Geared towards the consumer and the simplified CEA color coding scheme for antennas.
Antennaweb and TVFool are different tools intended toward different audiences. Any suggestion that it's a "conspiracy" would be born out of ignorance of how the processes work and the purposes of the tools.
Old 10-Apr-2012, 7:38 PM   #7
frank55
frank55's Avatar
I don't know who has more ignorance!
i think the ignorants are those that believe that this is the way to inform people of a wide range of available options, instead of protecting a few local stations and providers.
I use to believe antenna web for many years that i only could get 8 stations.
Old 13-Jun-2012, 10:40 AM   #8
Blackbeen
I prefer http://www.antennapoint.com/ over web for this reason.
Blackbeen is offline   Reply With Quote
Old 14-Jun-2012, 3:43 PM   #9
Please note that the purpose of our Antennapoint web site is specifically for that one purpose. It doesn't attempt to analyze signal paths or do anything more complicated than checking distances when it makes antenna suggestions.
Old 14-Jun-2012, 6:10 PM   #10
Dave Loudin
ADTech, I found outdated information concerning two stations in the DC area (transmitter powers incorrect for WJLA and WUSA.) Of course I don't know how or how often FCC data is pulled in, but something is not quire right. Of course, power isn't that important if only distance is used for further processing.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
