20-Feb-2012, 11:15 PM
#1
San Diego 92120 Antenna Advice
Is there an antenna that members would recommend. Hoping to get channels 6 (South of the border), 8, 10, 15, 39, 51, 69. Would be great if I could receive channel 6 - but not a deal breaker if I cannot get it. Do not need Spanish language channels. Single TV. Prefer not to mount an external antenna at a height greater than 15'.
http://www.tvfool.com/?option=com_wr...0b865a50d9f426
An indoor Mohu pulls in channels 15, 39, 51 and 69. Channels 15 and 39 however are not reliable.
Thanks,
~Vamsi
21-Feb-2012, 12:43 AM
#2
When you ask about reception of channel 6, I have to presume you're referring to real channel 23, XETV-DT, a CW affiliate.
A 4-bay panel antenna such as the Antennacraft U4000 aimed at about 150° should cover signals broadcast on UHF.
You may need to add a high band VHF antenna such as the Antennacraft Y5713 aimed at about 275° to make the ABC and CBS signals reliable.
The two antennas can be combined into a common down-lead using a UVSJ.
If the well is dry and you don't see rain on the horizon, you'll need to dig the hole deeper.
21-Feb-2012, 1:43 AM
#3
Thanks,
~Vamsi
Your Mohu Leaf is a UHF-only antenna. WFMB (RF-8) is Hi-VHF. XETV (RF-6) is Lo-VHF. You also have Spanish language and low-power stations in the VHF band. This is the basis of GroundUrMast's recommendations.
21-Feb-2012, 3:26 AM
#4
You are right. I went back to the tvfool report and switched to digital only and saw that CW is on 6.1 (real ch 23).
Thanks,
~Vamsi
21-Feb-2012, 7:27 AM
#5
Tv antennas and Tv reception
For reception of the groups of digital tv stations/channels to the , north , north west , south - south east. Install a Antennas Direct C2V antenna with a Antennas Direct CPA-19 preamp aimed at about 145 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Remove the reflector screen from the C2V antenna so the antenna will receive tv stations/channels at the back and front of the antenna. http://antennasdirect.com. The C2V antenna and preamp will be mounted above the roof. Here are some antenna mounts, http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Type the word ronard in the http://www.solidsignal.com search box or buy from ronard.
21-Feb-2012, 3:29 PM
#6
I'd try a Winegard HD-1080. It just so happens to have a VHF directional pattern that's backwards from the UHF, which is exactly what you need.
http://www.winegard.com/kbase/upload/HD-1080.pdf
Aim it at about 145°, halfway between the US and Mexican UHF stations.
Peformance wise, Ground Ur Mast's suggestion is better.
I'd be afraid that there may be too much multipath for a C2V to be reliable on channels 8 and 10.
21-Feb-2012, 6:08 PM
#7
And the same about multipath can be said about the HD-1080. And to make the U4000 receive more effectively in other directions , unclip and turn the reflector rods to the vertical position from the horizontal position.
22-Feb-2012, 1:24 AM
#8
I was not able to find these antennas in a local store. Leaning towards an online purchase. Is GroundUrMast's suggestion a more complex but sure to work solution? Because I am seeking to eliminate any returns.
Thanks,
~Vamsi
22-Feb-2012, 2:52 PM
#9
I would agree with your conclusion.
22-Feb-2012, 3:31 PM
#10
Thanks Tower Guy.
I am off to getting the two antennas. One for the UHF and one for the high-VHF.
Now this brings up questions about mounting.
1. Can I mount both the antennas on one mast? If yes, which antenna goes on top and how much separation is required between the two?
2. I currently have a Dishnetwork dish. Can I reuse the mounting - say for example with something like: http://shop.willyselectronics.com/br...it/4,7255.html
3. Something I only thought about based on the Moderator's name. Do I need to ground the mast? If so how?
Thanks,
~Vamsi
22-Feb-2012, 9:06 PM
#11
1. Yes. I'd put the UHF antenna on top with at least 1' spacing and 3' is better.
2. If it fits, the strength should be OK.
3. Route the feedline near your power panel, use a ground block to tie the antenna ground to the power ground.
http://www.solidsignal.com/pview.asp...One-RG-6-Cable
