Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates > TV Database Updates
Old 12-Feb-2012, 2:36 AM   #1
yamahopper
Recption correction at Scio,NY 14880-9635
TV Signal Analysis Results
Suggest that I should not be able to receive much of any thing with out about 200' tower.
I am getting good reception on 3 of the major Buffalo stations at my location with 60% or better signal strengh.With roof mounted mast 34' from ground with XG91 Antenna Horizontally mounted,Also Radio Shack Antenna mounted High-Gain pre amp (p/n:15-321) with very old CM rotor.
The Channels that I am getting are:
WGRZ-DV 2.1
WGRZ-DV 2.2
WIVB-DT 4.1
WKBW-DT 7.1
I have not checked to see what others I may be able to pick up yet.But I do plan to install a 50' tower this spring.
Signal Analysis Report:
http://www.tvfool.com/?option=com_wr...0b86db97273fa9
yamahopper is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
