Old 5-Nov-2011, 2:44 PM   #1
Trip
RabbitEars Webmaster
Send a message via AIM to Trip Send a message via Yahoo to Trip
Chattanooga Corrections
Hello,
Here's my new plot: http://www.tvfool.com/?option=com_wr...4bbaa60ba6c757
Just wanted to make a few notes about network affiliations and virtual channel numbers in the Chattanooga area.
WTVC should be 9.1
WNGH should be PBS
WELF should be TBN as 23.1
W31DO-D should be listed as "Pending" and Ind, not sure where it will map
WYHB-LD should be Ind as 39.1
W26BE and W21BZ should be Rel
WKSY-LD should be Ind as 21.1 and you are using the permit facility for 22 rather than the licensed facility on 21. The permit facility should be "Pending," while the licensed facility should be "Current."
I hope these updates help. Have a pleasant weekend.
- Trip
Trip is offline   Reply With Quote
Old 6-Nov-2011, 11:23 PM   #2
Dave Loudin
No more VHF-LO adventures, then?
Old 7-Nov-2011, 6:00 PM   #3
Trip
Not unless I want to toy with e-skip or trying to receive WUOA at 140 miles.
- Trip
Old 10-Nov-2011, 12:56 AM   #4
tripelo
WWWB-LP (3,000 Watts Pending)
...VHF-LO adventures...
Anyone know what WWWB-LP is broadcasting (programming)?
It shows on Trip's Chatanooga 'Pending' TVfool plot as Channel 3.
Other TVfool plots (further North) list WWWB-LP as currently being on with 300 Watts, the 'Pending' lists it with 3,000 Watts.
Old 11-Nov-2011, 7:38 PM   #5
Trip
Got an antenna setup, and three Atlanta stations are here 24/7: WSB, WAGA, WGCL. WUPA tries but there's a weak analog on 43 interfering, otherwise it would be in too. Same for WATL with an analog on 25. WBXX is very hard to catch which makes me think WPCH is interfering.
- Trip
Old 11-Feb-2012, 2:01 PM   #6
Trip
Good morning,
I wish to make an additional set of corrections to WOOT-LD.
Under "Current," WOOT-LD is now operating with its 5 kW STA. Under "Pending," the WOOT-LD construction permit has been modified and BMPDTL-20111114AXS should be shown rather than the old permit currently shown in your database.
Thank you!
- Trip
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
