Originally Posted by rabbit73
Yes, you would think so. The tvfool report knows about the hill, but it doesn't know about the trees in the WWLP signal path. Trees block TV signals.
An MCM 30-2476 with the front end tilted up and a preamp might pick it up.
Is this better than the other VHF antenna I already have?
WJAR coverage:
An Antennas Direct 91XG or a Solid Signal HDB91X with the front end tilted up and a preamp might work.
I was actually able to pick up WJAR Saturday night however now today it is gone. Is there a decent way to combine the two different types of uhf antennas so I can keep the Mohu pointed toward boston and one of the above toward WJAR? With the pre-amp built into the Mohu I am guessing I would have to combine down in the basement.
