Old 10-Oct-2020, 8:11 PM   #153
blackstone
Finally got a chance to get back to this
I only messed with the DB8E, so far.
Did a continuity test on all the cables and all read "Open"
Broke all outside connections and applied dielectric grease.
Found one connection was a little loose.
Checked all connections for tightness.
Had a Mediasonic tuner to see if that might help.
Didn't, so I removed it and am sending back.
Was able to get WTAE RF 27 Virtual 4 badly pixelated.
I haven't had any luck getting WWCP 8 even though I moved the CM for that.
Both my preamps are in the basement.
Could they be bad?
The splitter amplifier is brand new
Any suggestions are appreciated
Thanks for your patience
blackstone is offline   Reply With Quote
