Old 9-May-2019, 7:13 PM   #6
newmguy
Are your TV channels on 20 and up? If so this will allow the use of channels 14, 16, and 18.
https://www.solidsignal.com/m/product.aspx?p=nf-469
no there are 3 channels, 14, 15, and 19
This model would allow use of channels 65, 67, and 69.
https://www.solidsignal.com/m/product.aspx?p=lpf-750
You will also need the 20 dB attenuator on the output of the modulator.
So where would this install?
Between the cable coming from my antenna to the splitter input?
or
From the modulator output to the splitter input?
newmguy is offline   Reply With Quote
