Old 2-Jan-2015, 12:23 PM   #8
Stereocraig
Originally Posted by devidog View Post
Thanks for the reply. I'm just looking for a more analytical solution. I'll get a pre-amp and replace it. If that don't work I'll take the mast down and replace the balun. Just seems like there should be a way to check things out and not be a "parts chaser".
Other than testing for shorts and/ or continuity on cables, the equipment to give "analytical" solutions, can be a bit on the pricey side.
Common schmoes like me, are pretty much relegated to being "Parts Chasers".
This does in fact, sound like one of the connectors on one of the circuit boards may have become loose.
Some RG6 is not very cold climate friendly and can create additional stress on the fittings, from stiffness.
