Old 4-Dec-2011, 2:06 AM   #2
Dennis
Antenna Selection HELP!
First -- Thank You for assisting!
I want to upgrade an existing antenna (~30 y/o weingard-type analog) that is placed in the attic. I will likely place the new antenna in the attic as well.
The TV signals are often pixelated with weather changes, and more and more station-signals are becoming too weak to display.
Signal Map Link: http://www.tvfool.com/?option=com_wr...ec123f8415086f
The height is approx 20+', the current antenna is connected to a 'converter' box ... to an analog tuner TV. What antenna types/brands, rotators, signal amps, connectors, etc. would give an optimal signal in this setting?
Thanks Again,
Dennis
Dennis is offline   Reply With Quote
