Old 10-Jul-2012, 7:16 PM   #1
fgth
Digital OTA TV in Fremont Mission Hill area
Hello,
My setup has once worked in Cary North Carolina, and now it does not here in Fremont California.
I am puzzled to see if I am in a shadow or what else...
Setup is:
EZ HD Antenna: http://www.dennysantennaservice.com/...v_Antenna.html
Connected to an Hauppauge WinTV-HVR-1600 card.
The antenna is not yet on a pole, but it's still point toward San Francisco peninsula. If not perfect, I should still catch a few channel, just to have a clue I am on the right track before I set up a pole, etc.
The issue is that I get nothing, not even a hint of low signal.
I've tried to change cable, connector (75-300 Ohm converter), changing the PC card slot, but no luck.
Any other folks in the area? Any tip?
Thanks!
I need to get ready for the Olympics!
Francois
fgth is offline   Reply With Quote
