Old 24-Jul-2014, 2:12 PM   #6
StephanieS
+1
If your friend wants a large antenna, the Y10713 is the largest single band high-VHF antenna on the market. Plus, it is the ideal antenna when working weak high-VHF signals. It is also modestly priced as you can find it around 40 to 50 dollars.
I would prefer in this weak signal situation having a two antenna system with one dedicated to each band (uhf and high-vhf). This allows for each antenna to focus on its area of strength.
UHF antennas (what you have in your friend's 4 bay) are capable of capturing enough VHF signal to not necessitate a VHF dedicated antenna. This applies generally to green shaded signals only of good signal strength though. The VHF signals we are discussing are weak enough a dedicated high-VHF beam is the complete way to go.
The RCA preamp is great bang for the buck. Run one myself.
Report back how things go.
I'd add an Antennacraft Y10713 + RCA TVPRAMP1R to the system as I was removing the Radio Shack amplifier. The RCA amp will have inputs for both antennas and it will have much better noise/distortion performance.
