Old 18-Oct-2013, 11:32 PM   #6
Pratical and Useful Information.
A clearer picture of the antenna will help with identification.
Aim the antenna at about 224 degree magnetic compass direction , here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ ' Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and Select 'Air Channels' ~ ' Antenna Channels'.
Scan for channels.
The Digital Broadcast Tv stations/channels that to be received are.
WUFT , Real UHF channel 36 , virtual number (5.1-2-3) PBS channels.
WOGX-DT , Real UHF channel 31.1-2 , virtual number (5.1-2) FOX and Movies!
WCJB-DT , Real UHF channel 16.1-2 , virtual number 20.1-2 ABC and The CW.
WGFL-LD , Real UHF channel 28.1-2 , virtual number 28.1-2 CBS and MyNetwork.
WESH , NBC and Me-Tv.
Last edited by teleview; 20-Oct-2013 at 5:40 AM. Reason: Clarify information and typos.
