Old 25-Oct-2014, 5:58 PM   #1
devidog
More accurate Missouri report
If you looked at my previous thread, I had an issue with coordinates ADTech straightened it out for me. I have pretty much decided to go with...
DB8
Rotor
RCA-TVAPRAMP1R
Y10713- mounted stationary on the mast @ 25'
http://www.tvfool.com/?option=com_wr...d2435829a52355
When aiming the vhf antenna, I have two stations in the 300 deg azimuth area, KRCG and KOMU. The terrain in that general direction is a creek bottom with edges above the height of the antenna but is closer to 280 degrees . What is more critical, exactly aiming at the tower or trying to avoid the edge?
I'm trying to avoid to much trial and error as I'm not sure if I will be able to reach and adjust the yagi w/o bringing the mast back down. The mast will have to stay stationary at due north for orientation of the rotor.
devidog is offline   Reply With Quote
