Old 21-Sep-2012, 11:59 PM   #3
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for digital broadcast tv reception.
http://www.solidsignal.com has a ANT751 antenna with a J type antenna mount , low dollars.
Aim the ANT751 at about 270 degree magnetic compass direction , west.
Tv Tv transmissions are strong.
A antenna amplifier is not required.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
It is best to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception.
At your location that is , north west , west , south west.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , somrtimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
