Old 22-Jul-2011, 7:13 PM   #61
SVTarHeel
Originally Posted by SVTarHeel View Post
So, the bottom line is: would you have any thoughts as to my best bet? The way I see it, my options in order of increasing cost would be:
  • add an amplifier (before the splitter) to the existing rabbit ears setup
  • go with a better antenna
  • use a better antenna and an amp
(Or maybe bypass all that and use the existing mounted antenna somehow.)
My previous post, quoted above, is at the top of page 2. With dcp12345678 narrowing his ION solution, I was wondering if there were any more thoughts (in addition to Scott784's helpful antenna ideas) for what I am trying to do. I'm specifically wondering if an amplifier is needed or recommended or what else I might be able to do/try to feed both tuners.
SVTarHeel is offline   Reply With Quote
