Old 18-Sep-2012, 12:45 AM   #4
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Above the roof install a Antennas Direct DB4e antenna aimed at about 325 degree magnetic compass direction.
Install a Ultra low noise , KitzTech KT-200-COAX TV Antenna Booster Remote Power Fed , amplifier for the weak Tv signals.
If you do not have a antenna mount here are some , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.kitztech.com.
It is best to locate the antenna at a location that has the lest amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
