Originally Posted by rabbit73
Hello, Tony
I agree with GroundUrMast on the antenna and preamp.
Here is a report from rabbitears.info which should have a more accurate list of channels:
If you stick with Atlanta, you shouldn't need a rotor. If you do decide on a rotor, the older Channel Master CM-9521a rotors didn't hold up for long, but the newer 9521HD rotors are getting better reviews.
If you want a heavier duty rotor for the big HD7698P antenna, I suggest the Yaesu G450A, which is a ham rotator.
https://www.dxengineering.com/search...torder=Default
Thanks rabbit73, way back I used to go on the roof to adjust the antenna some times turning to Macon but mostly after strong winds the antenna would turn a little. If I got it just right some of the weaker stations did well.
With the added height and a amplifier a rotor may not be needed, but I would like it to be a one and done install if possible although I know some tweaking may be called far (story of my life).
Reading reviews on amazon over all the 7698p gets 4 1/2 stars although some plastic bits seam to be in question on a few.
Any thoughts on this antenna:
http://https://www.solidsignal.com/pview.asp?p=hdb91x
Thanks again rabbit73,
All the best to you, Tony
