Old 16-Mar-2017, 8:38 PM   #4
If you want an answer that is in in accordance with the NEC, the only kind that Tom or I or or anyone else who is informed will give, here it is: "The mast's embedment in the ground does not meet the requirements of the NEC for grounding purposes."
Now, should you properly bond the mast and the coaxial cable's shield to your structure's ground electrode system, then your installation does meet the criteria set out in the national code.
You'd do best to call a local building inspector (if any), a local electrician, or bone up on the NEC as a study of interest.
