A Simple reception situation.
For the Chicago Digital Tv stations/channels.
Above the roof install a Winegard HD7084P antenna with a Winegard AP8700 preamp , aimed at about 148 dgree magnetic compass direction.
Here is how to aim antennas ,
For 1 Tv connection use no splitter.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at ,
http://www.hollandelectronics.com , or ,
http://www.solidsignal.com.
Here are some strong and sturdy antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronard.com/34424560.html ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
Here are some places to buy antennas and etc. ,
http://www.solidsignal.com ,
http://www.amazon.com ,
It is best to install the Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
