Old 7-Jan-2012, 6:25 PM   #26
MisterMe
Originally Posted by otadtvman View Post
Thanks for the info Dave.
AD is the 1st I've seen to use this term. Is AD saying that precise aiming is required with the new DB4e to acheive the max gain that's advertised?
This is true of all antennas. However, maximum gain is not always necessary. You may receive sufficient signal at 95% maximum, 80% maximum, or less. If you live in an area where the transmitters are in different directions, then it may be possible to find an optimal direction where the antenna receives most of your channels without rotation.
MisterMe is offline   Reply With Quote
