Old 7-Jan-2012, 2:30 AM   #22
be236
It's not a direct comparison, but my recent purchase of a Winegard HD8800 has been disappointing. I had to run to the hardware store to replace missing machine screws which could and should have been packaged better... and had simply fallen out of the box during shipping. There is no anodizing or other coating on the aluminum parts, so corrosion will be a problem a bit sooner. (To be fair, the Antennacraft is not anodized either.) The electrical performance of the HD8800 has been significantly less than lesser antennas, including a crudely built DIY 4-bay w/reflector. At present, modification of the combining harness is a 'back-burner' project (after some reading over at the Antenna Development section of digitalhome.ca).
I have to agree! I just bought HD-8800 and compared with my home-made 4-bay M4 and SBGH, it has similar performance (eg, not any better).
I'm a little disappointed, since I was hoping it would have higher gain to pull in my low-UHF channels (RF 17 to 32).
Alas, looks like I'll have to try and order a CM 3023 instead Yagi (trying to avoid 91XG since many reports says it's not good at low-UHF)... but... who knows, it may work in my situation/location...
