Old 16-Mar-2017, 8:36 PM   #5
Originally Posted by nickgalliart View Post
Thanks for the reply!
The pole for the antenna is in the ground about 20 feet away from the house's electrical service ground. If I use a grounding device like what is in your profile picture, should I just run a separate AWG wire to the house's electrical service ground?
That's what I have done with my masts; A dedicated bonding connection from the mast to the existing electrical service grounding system using #10 AWG. I treat the coax shield bonding as a separate, but equally important connection.
