Teleview, I was not confused about the channel label per se (but thanks for the information). I was just wondering why did you recommended a "VHF channels 7 through 13 antenna" if my UHF antenna picks up channels 10, 12 and sometimes 13. It seems unnecessary, that's all.
_________
Okay... Back on topic, can someone please answer my specific questions about adding an amplifier?
- Is the CM-7777 the best choice for my configuration?
- If I use the CM-7777 what should I do with the FM trap?
- Does the CM-7777 has an internal VHF/UHF switch? If so, what to do with it?
- Should I be worry about overload because of some of the powerful signals I get?
- Is there a power inserter like the PCT-MPI-1G with two ports? If so, should I use it to replace my current splitter?
- Are there any other things to consider? (while keeping my existing configuration)
Thanks,
Stick da Chalk.
