Old 21-Jan-2010, 2:56 AM   #3
tvlurker
Originally Posted by andy.s.lee View Post
Hi,
I'm sure this is possible. It's simply a matter of finding the time to do it. FM transmitters outnumber TV transmitters, so it's a little more data to sort through, but I don't see any reason why it can't be done.
Does anyone happen to have a link to the FM database download site?
The FMSTATIO.dbf file is in the same zipfile as the TVSTATIO.dbf file, available from http://spectrum.ic.gc.ca/infoback/dgse/dbf/baserad.zip (ignore the message at http://spectrum.ic.gc.ca/infoback/dg.../baserade.html that says the files are from May 9, 2009, as I just downloaded the set today, and most of the files are from January 20 2010.)
You could also try the frequency search database at http://sd.ic.gc.ca/pls/engdoc_anon/w...cy_range_input but I don't know if you can get antenna pattern data out of it.
tvlurker is offline   Reply With Quote
