Old 1-Aug-2013, 9:19 PM   #6
Most preamps and DA's will tolerate some heat... but if it intolerable for you, it's too hot for the equipment. Is there a closet or similarly convenient location below and near the antenna? The CM-3410 can be powered remotely if you need to.
http://www.channelmasterstore.com/Am...p/pctmpi1g.htm
http://www.channelmasterstore.com/An..._p/cm-3410.htm
